Hello,
Just bought a used Uniti Star from an authorized dealer, and so far I am very happy with it. It does get pretty warm in use. Is this normal?
Hello,
Warm is fine, there’s a lot of electronics crammed into that box and Naim design the case to act as a heatsink. Digital circuits tent to run quite warm even when idle, whereas the amp will warm up more when you crank up the volume. Still if the ambient temperature is high, you should try to make sure that there is plenty of air circulation around the box.
Thank you!
