Uniti Star
Hello, there is a little hole in the front of the unit. Just below the cd slot. Does anyone know why it’s there and what it’s for? Thank you.
I think you are referring to the eject button, into which you can push something like the end of a paperclip to encourage a CD to eject if it doesn’t happen automatically.
Either as @ChrisSU says, or Tinworm.
The Uniti Star freezes up sometimes when I’m ripping. Have you heard of this problem? Thank you.
I’ve never had this happen
I am having problems ripping CD’s with my Uniti Star. When a cd cannot be ripped, the unit freezes up, and cannot be unfrozen, unless I unplug the unit, and wait a while. When I restart the unit I can continue to rip, providing that it does not freeze up again. Does anyone also have this problem? Thank you for reading.
I haven’t come across this. I think you should contact Naim support.
Thank you.
Thank you.
