Hi,was thinking about connecting a naim uniti 1 to a linn lk85 power amp, will this work, and how do you connect correctly.
Yes you can! The pre-out is a DIN connection on your Uniti, you may need a custom cable for a the LK85.
Many thanks for your reply,
