an additional problem to my other UPnP issue. Looking for solutions! Eternal appreciation guaranteed!
Situation: I own a Uniti2 hardwired via ethernet / tested also on wifi. I have set up my music collection drive as NAS via my Fritzbox router. I want to play losless files on that harddrive using UPnP.
Problem: While the Uniti2 recognizes the harddrive, shows the files etc. it will not play FLAC or WAV or any other losless formats - “Can’t Play - Unsupported File Format”.
It plays MP3s of that same NAS harddrive just fine. It alsodoes play the FLAC files when I use the Uniti2’s USB input to connect the drive directly.
Any ideas? I think others here have successfully used their Fritzbox in a similar scenario? Thinking of @robert_h and
Thank you, Robert! That was my first thought, too, but I also saw that webpage AND my VLC player was able to play the formats from that NAS just fine.
Thinking it might be a formatting issue? Others report that unplugging the harddrive several times (not Fritzbox but similar issue with FLACs via NAS) has helped…
Thank you, @Paul_C . Not yet. I have forever just found the solution / problem (after thinking it has to do with formatting as suggested in this thread). But the solution was different:
The Fritzbox created “shadow files” without any info but the same filename for each song. To find the real FLACs I needed to scroll down quite a bit. But they are all there and sounds great.
