Unitilite Preamp Out
I’ve seen a s/h Unitilite locally. At the moment I have a Star downstairs and a 202/155 in my home office. I listen to Spotify quite a bit and also have a stupidly large CD collection that I still enjoy playing. I would add a Naim streamer and CD player but cost wise that’s not realistic. With the Unitilite preamp out, could I connect that to the 202? I read the pre-amp out is taken from after the volume control so I guess I would just need to get the right level set on the Unitilite.
Thanks in advance.
Jim
The Unitilite will work fine as long as you are careful with volume controls so that your ears don’t get a nasty surprise. A Uniti or Uniti 2 would be better in that they have a line out, but the Lite will still work. You could enable AV bypass on your 202 if you want to use only the Unitilite volume control.
Thank you Chris.
Jim
