This is my 3rd Qute but first Mk1 and I’m having a couple of issues.
I have a turntable connected which is recognised by the Naim app and plays fine and without issue but the internet radio only has 3 presets possibly from the previous owner but won’t load or can’t find any other stations. I just get the buffering symbol but nothing else.
Also I’ve connected a USB stick to the front though it’s recognised all of my files and says they are added none will play.
I’m wondering if I should return everything to factory settings and start from scratch.
Thanks I will do that and get back to you. I have to say though with the Planar 8 as a source and with the budget Dynadudio Emit10 speakers that little amp sounds very nice indeed the Qute is up there with my favourite Naim products.
