In this case, Iām afraid that if you are sure you hear a difference between straight or transcoded flac on the 272, then your only options are to keep the US or use another NAS with Asset or similar. (Or a Raspberry Pi if you like to tinker, and keep the WD as pure storage)
So when you say US SSD, this is not a proper US SSD as built by Naim, which has a trivially tiny internal SSD and relies on a NAS to be the Music Store?
I am assuming that what you have is basically a US which had a 2 TB hard disc drive inside, but the hard disc drive has been replaced with a 2TB (or similar) SSD?
If itās the former then you donāt store downloads in the internal SSD, which is for the firmware and a ripping buffer. If itās the latter then you should be able to navigate with a PC or Mac to see the Music/MQ folder where the USās own rips are stored and the Downloads folder where you can store downloaded or other rips that werenāt made by the US.
In any case, if you are using the Naim app, the downloads and the rips appear in one listing, so they should be there somewhere. If you are using n-serve for IOS then you can see the downloads folder separately, but there is no reason to do so.
I think weāve had this conversation before
Just open the folders on a computer then copy the files from one to the other, just like any simple file transfer.
You have to wait until the US scans the downloads. I remember it taking several days sometimes and rarely less than an hour or two before it picked them up. You could try restarting your US and see whether that helps. So far as I remember, the only way to force a rescan is to use the Windows Desktop Client which does include this control.
But I donāt think the Mac version of n-serve has this feature, but @ChrisSU may know better than me.
On earier firmware (or possibly that was just coincidence) I recall that downloads could sometimes take a while to show up in either N-Serve or the Naim app. Itās not an issue I still see though.
You can rescan the drive on N-Serve for Mac which might help.
My advice to you is give it back to your dealer. Get yourself a decent nas and load Asset. Itās cheaper, more flexible and very likely will sound better. The UnitiServe is outdated, inflexible and a challenge to back up. Give it a miss.
