Since the last update of the unity star in May, I have to power it down and restart it 2-3 times a week. It suddenly starts to have drop outs, cannot change to a different CD played from a usb-connected hard disk, cannot rip/play or eject a CD. After the restart everything works fine for a few days.
Anybody experiencing similar problems?
Mines ok but I have avoided the software upgrade like the plague…
Hi Wokn,
Can you please contact Naim support who will be able to support you with the problems you’ve reported.
support@naimaudio.com or +44 (0) 1722 426600
Thanks.
Roland
Mine’s ok and I HAVEN’T avoided the software upgrade like the plague…
I only avoided it due to the many posts complaining about the outcome. Good to see it works for some, shame others have had their Naim experience ruined…
See here;
Updated
