My nait xs2 remote doesn’t work and nor does my cxn 1 remote. I know nothing about universal remotes but would love a remote to control these two things. Anyone able to help?
Edit: I did read someone saying you have to train a universal remote using your old remote, but I obviously can’t do that. So what can I do?
You can configure a universal remote using a code instead of using your old remote.
The universal handset should come with a list.
RC5 is a common protocol that many remotes use. I used to be able to use my XS3 remote to control my old Arcam CD player.
Just try several codes from the list and see what works.
