Sometimes an album that I’ve saved in the NAIM app becomes unusable and unremovable, probably due to a copyright issue or the like, I would imagine. If I go to my Qobuz app to load another available copy and delete the old one, it deletes from the Qobuz app “Favourites” list but doesn’t from the “Albums” NAIM" app list, where it stubbornly refuses to allow deletion, as in the two pairs here.
I had the same issue, but indeed deleting from the streaming app such as qobuz or tidal did the trick. Are they still there after you had closed the Naim app and restart it.
Log out of Qobuz in the Naim app, and log in again? (Might trigger a fresh sync as well; I don’t know, if there’s the risk to “loose” anything by this.)
I doubt it. The option is “Include Qobuz favourites on home screen”. If you unselect that, why would the Naim app reach into the Qobuz system and delete them?
My thought is that when you select it again, the Naim app gets a new list from Qobuz, which wouldn’t include your deleted ones.
But I don’t know, as I don’t have that option selected myself.
Ok. So if you log into the Qobuz app and look in the list of favourites, does it show the deleted favourite still? If so then this is a Qobuz issue.
But if the Qobuz list is ok, then it’s a Naim issue. With the Naim app, if you delete it and then reinstall it, you delete all the data associated with the app, which will include any list of Qobuz favourites that the app has stored. So then when you sign into Qobuz in the Naim app, it should repopulate your Qobuz favourites onto your Naim app screen.
