Upgrade uniti star to nsc 222 and nap classic 250
thinking of upgrading star to npc 222 and classic naim 250 amp and if so what are the overall benefits
cheers
Whilst the SQ should be seriously improved all round, both in details, soundstage and dynamics, it will also depend on your room, speakers and personal taste. As ever, a home demo is recommended, or at least an extended listen at a good dealer’s who would help you compare across music that you like. If a dealer demo, and he doesn’t have your speakers, then I’d suggest taking them and your Star with you.
It should be a very significant improvement. The Classic 250 isn’t in the same league as the New Classic version, but it will still be good. You will need to source a suitable lead though, as the one supplied with the Classic 250 isn’t compatible.
There are two versions of the Classic 250, the 250.2 and the 250DR. The latter is subjectively better. Always check the age and service history of any such amp.
I went from the Nova to the NC 222/250 with my Kanta 2’s. Fantastic improvement. Loved the Nova, but this is a major cut above.
