Currently have a 150x and 112x…Best way to go for upgrade
I had a 150x and thought it was a fantastic amp. Upgraded to a 300 and lost some sparkle that didn’t return until I added an XPS DR to my streamer. I guess it comes down to what you want to spend now and your end game.
Flatcap
My first Naim system was CD5/Nait 5. The dealer demoed what a Flatcap did and I bought it too.
What is thy source?
Flatcap or Hicap will make a big difference.
Go for the hicap and you can keep it for use later if/when you want another upgrade to a Nap 200 or a nac 282. If you are looking to upgrade either the 112 or 150 I would go to the 282 as the first step.
I’d second that. 282 will get plenty out of the 150. Wish I’d done that a while back rather than go to 202/200.
Yep, I made that mistake.
Thanks for that…sounds like a plan
Source and speakers
