Upnp brige from sgc installation
I use upnp bridge hw from small green computer to roonify my 272 What to type into the ios browser, to configur the upnp .?
I assume you are missing the instructions that it came with?
The link may be considered a ‘commercial’ link so I cannot share it without breaking forum rules.
@Richard.Dane
I’d imagine that an instruction manual should be easy enough for Kim to find online?
If it’s the Sonore bridge then this thread may help
https://community.naimaudio.com/t/roon-with-sonore-bridge/12904/15?u=james_n
Thanks, found it
