USB Icon Removal from Dashboard in app?
I stupidly managed to put the usb icon back on my app dashboard. The webclient no longer offers an option to disable it and not have it showing.
Is there another work around to clean up my dashboard?
Thanks,
Graeme
Try system settings/Input Settings
Thanks - I tried that first, no option to switch it off unfortunately.
Hm, strange - wild idea, what happens if you edit the name to remove the 3 USB characters
You might also want to go into App Settings/Sources layout and move the USB to the end of the list
Solved via webclient. Thanks all.
How did you do it?
Webclient on a PC. Scroll down to ‘Settings’ ‘Inputs’ ‘USB’ and disable.
Doesn’t work on an iPad.
Now bookmark this thread so you can quickly figure out how to put it back to enabled!
Haha. It’s the icon on the dashboard that annoys me. Sounds just the same on or off.
