Used NAC 552
You could, but I wish you the best of luck with that. To get the evenness and flatness required, I’m told that you start with a very large “perfectly flat” sheet and then a laser eye looks for the flattest and most even areas large enough to cut out a suitable piece. The tolerances are crazy here so it’s highly specialised and very expensive. Because of this, the cost of the SL2 interface plates was way beyond what anyone might imagine and probably why they ended up costing way more than originally envisioned; Of course you couldn’t skimp here as otherwise they just wouldn’t work properly - truly an engineers speaker.
The Naim glass is from Pilkington, if you search the forum for the name you will find discussions with details
What if we didn’t need it 100% super flat… :grimacing: It’s just to place our equipment on with slight imperfections hidden…? [ok I’ll stick to Naim glass… more cost effective for once… :upside_down_face:] lol
Thank you… Yes I’d read this earlier somewhere here but didn’t note the name.
Naim Pilkington glass seems to sound about the fastest so far…
but I guess we don’t mind looking for alternatives to try for some fun
in our hobby to see where it takes things.
The feet on the 500s (and SuperLine) are hard metal, and the internal suspension only works as designed if there is no rocking
Yes… it’s a wonderful work of engineering and some serious thinking to address microphony.
Interesting idea of aluminium meanwhile.
A number of people on this forum believe that the positioning of the Naim cups for the ball bearings provides a means to tune each box. From a physics perspective this makes complete sense. However, the theoretical modelling might be complex as the speakers and room probably affect the model quite a bit. Essential it is the sound vibrations including the those coming up through the racking that are the issue.
In another thread a while ago an alternative brass cup and non metal ball bearing was described and found to be a good alternative.
Phil
Thanks Phil.
Hi Geko
Have you seen this system for making glass vibration isolation platforms?
Basically, on silicone nitride balls, in dents in brass cups.
It works well for me on a Quadraspire rack.
Jim
Any luck with re-racking?
Hi JimDog,
Yes, I followed this with interest and fully understand what was trying to be achieved. I’d already done something similar but with a set of die taps. The round ones have a small four point contact on a ball bearing and are hardened steel. However, going back to the standard shelf I always thought it had a slightly more rounded and organic sound. I just couldn’t get rid of that pitchy glass character whenever I tried glass on it.
If I’ve taken anything away from my experimentation it’s that mass seems to play an important part in the equation. I think the Mana tables gives us this clue. Lots of stacked similar, double or triple mass tables. It’s like there is either a constructive or destructive energy sink. When it’s right it sucks away energy very quickly and very efficiently. When it’s wrong it seems to reflect it. Just my personal opinion.
Hi,
A slightly unrelated question.
I can’t help to notice that these naim boxes are kept in a cupboard with doors and no ventilation. Now we know the boxes generate heat (for sure the power supplies). Is there not a danger of higher temperature inside the cupboards affecting :-
  1. Their performance when playing music
  2. Reduce the equipment life with the parts inside getting damaged or requiring more frequent service than normal.
Richard, is there a ‘normal operating temperature range’ the units should be kept at? Or an optimum temperature maybe?
I don’t want to divert the thread of the OP, but want to use this example to understand the experience of other members and Naim’s recommendations.
Thanks,
Not just for some heat… but sound which frees up so much more when there is adequate space around Naim equipment. EM hum and microphony is a continual challenge.
Thanks Philp. That too.
@Richard.Dane any comments on the recommended operating temperature for Naim boxed?
Thanks,
Under normal conditions Naim pre-amps power supplies and power amps shouldn’t get hot. However, when power amps are asked to work hard then they will need too dissipate some heat. Free air flow helps here. The power amps have a thermal trip that protects them should the temp exceed 70 degrees C.
Network players can get quite warm thanks to all the ICs. As with the power amps, the casework acts as a heatsink.
Two weeks in I’m loving my used 552DR it really is a remarkable pre amp, big thanks to Vicki (my understanding wife) who allowed the purchase she’s now in bed but I’m enjoying a bit of Paul Simon - Graceland and even at low volume it’s never sounded so good!
My wife also Vickie allowed me both a 552 and 500……DR both :smirk:
I need to go on a dating app and find anyone called Vicki.
Seems like you can’t go wrong with that idea.
Thank you Richard. So no issue storing the units in a cupboard.
What is the experience of other people what have done this?
Thanks.
I wouldn’t say no issues. There can be issues depending upon a number for factors; the units themselves and how much air is there to circulate around them, overall ambient temperature, and how hard the amps are made to work.
Thanks for the prompt to revisit Graceland. Currently on headphones and sounding great!
