Basic setup question.Just got my Naim CD5X back from repair.Previously used with a non-Naim Power supply but I’m not so sure on setting it back up.Is this the basic order (when using a coax cable)?: 1.WITH the link plug inserted select the coax outputs via the remote -then- 2.REMOVE the link plug and THEN insert the DIN5 connector from the power supply"s cable into the ‘upgrade’ jack
If you aren’t using a separate power supply you should have the link plug fitted. Do this before powering up.
