Is it likely if you haven’t already combined with Amazon and link a voice activation to turn on the Mu-So 1st or 2nd gen using a Fire Cube.
I am 74 and struggle to turn on the wall plug.
You can turn them on using the Naim app on your phone. As long as they are on standby.
Once you turn it on at the wall you still need to touch the muso to wake it up, choose radio stations etc or alternatively use the app or remote. I don’t know if you have one already but you’d normally leave it on at the wall and then put it in standby when not in use. So there seems to be no need for voice activation.
We tend to use it as an old fashioned wireless receiver, leave plugged in at the wall and on. To wake it, wave hand over the top and press whichever preset is wanted… usually 2 as Radio 2 or 5 Radio Paradise Mellow Mix
