Not sure if I am missing something, but I cannot see where I adjust the volume when using the ap (via iPhone) so have to use the remote control (for the SN2). Apart from this niggle, I am very impressed with the Naim ap. Should add, I am simply streaming music from Tidal and it sounds wonderful. Any advice welcome.
You need to connect & set the NDX2 & SN2 for “System Automation”
The connection is done over a 3.5mm jack cable (IR Out to Remote In) & the rest is done in the NDX2 settings
