Volume control not working on Aton . It shows lighting up. And volume works with hand
control, and app
Have you rebooted it?
Is that a fancy way of saying turn it off and back on again?
No, it means that when you get really mad and kick it across the room, you have to kick it twice. It won’t make it work, but you’ll feel better.
Have rebooted successfully,thanks for help.
All ok,thankyou
