The volume sliders in the Android app are not verry accurate. That is why I set the more accurate +/- volume control (see screenshot). Unfortunately, this setting only applies to main volume control. When you use de multiroom volume control in the app you get the sliders again. If you set the app to +/- volume control you should expect that this applies to all volume siders.
Would it be possible, in the future, to have the +/- controls also for multiroom volume adjustments?
