Volume control on a NAC72
Hi guys, just a quick question. I have just returned from a friends house who has bought a NAC72, HICAP & NAP250. Sounds really nice, but on looking close at the nac72. His volume control line when turned completely down was on a slight angle more like 7’o’clock. Mine is at 6’o’clock and always has been. Does anyone have a answer for this, they both work fine. My NAC72 picture supplied.
Probably a slipped knob. You’ll find a little grub screw under the rubber outer cover so you can reset the position.
It looks like the knob has just slipped or been re-positioned on the spline. It’s usually around the 7 o’clock position at minimum volume.
Thank you, do you take the volume control cap off and loosen the screw and reset the position. I guess it is not the screw in the centre of the control. Many thanks guys.
This thread should help. About the rotary ON-OFF Switch of Naim NAP 140 : feel little loose
As far as I am aware, 7 o’clock is the correct starting point.
It was that when I first bought my NAC72, though it was slightly pulled out of position when the kids were growing up :grinning:
When I had the pre amp serviced by Darran at Class A, it came back with the volume starting at 7 again.
All sorted out now, a big THANKS for your help guys. Picture showing it in correct position.
Much better… :crazy_face:
