Volume mode in the app settings for second generation streamer why
Hi,
A while back I discovered a setting that was new for me at the time. When using my nd555 in the settings menu there is a Volume mode option that can either be hybride, fixed or variable.
there is no help for the 3 settings, fixed and variable probably is selfexplained, but hybrid?
Claus
Here you go.
You should use fixed volume for best SQ.
