Can anyone tell me the meaning?
Naim is changing the internet radio provider. (vTuner to in-house)
Currently both are working (for old favorites, the “catalogue” is all new already), but you need to recreate all your favorites from the current/new catalogue.
It should give a hint, when you “tap” on the warnings signs.
As @PhilippVH says, but exactly what you can do may depend on whether you are in UK or not and what streamer you are controlling with that Naim app. There is a whole thread about this……
Thanks for the info. I was puzzled by the warnings as all seemed to play fine
We’re doomed. Doomed. Doomed, I say.
