This is the one I used to use when i was in a High school with Nagaoka record cleaning spray!
You probably know, but the Hunt EDA design has longer carbon fibre filaments either side of a velvety/plush pad.
I did think the carbon fibre filaments seem coarser tipped than they did years ago, may be my imagination when I find an old one maybe I’ll do an A/B with an album I’m not that bothered about!
I’d consider the scratches I saw extremely superficial micro-scratches/scuffs and have to wonder if they’d even be audible, but I’m not keen on taking the chance with new or older well kept vinyl.
Is the Sonic Broom a current product?
Hi AC
Yes mate my first one lasted nearly forty years and I’ve just bought a couple one and for spare.
Use dry though no fluid.
It’s in the wrist action.
Actually, just realised that the newest ‘Hunt EDA’ brush I got was actually this very similar design:
Several of the low star reviews comment on scratching but they are a small percentage overall.
Makes you wonder if there were bad batches or others aren’t really scrutinising the surface post ‘cleaning’
No brush fibres on Sonic Broom
Out of interest did you buy recently from Amazon or elsewhere (the former only has a few 3rd party offers).
Every now and then I still use my old Discwasher brush that I bought when I was still at school out in the States (would have been around '82-83). It’s handy to have nearby, as is the matching stylus brush.
I like the curved edges I imagine that does the collect and lift too.
All in the wrist action…
Thanks - will investigate.
I’ve got the discwasher stylus brush but not the record cleaner.
My old vibrating AT-637 stylus cleaner brush is somehow solid, not sure if I used some fluid on it once (maybe discwasher?) and that caused an issue or if it’s just old and gone stiff. Have often wondered if I should try to replace the brush pad with something similar. The vibrating mechanism still works just that the tip doesn’t penetrate the pad as it used to.
Audio-T have an older article about it suggesting it was only discontinued because the manufacturing tooling broke.
Oh you have the stand, I have two pads and the stylus brush, liquid etc, but no stand, they still work pretty well!
There was a bigger stand you could get as well that also held the Zerostat gun. The Zerostat looked fun but I didn’t feel it worked very well, so I saved some $ and went for the smaller set.
I have the Zerostat bought back in the 80’s, it did/does work but you have to follow the instructions to the letter and it always seemed too much of a faff to use regularly. I recall purchasing the Discwasher and replacement fluid in the US where it was significantly cheaper. Wish I’d gone for the stand!
