I am an happy owner of NDX2 and now a new Supernait3
I connected the NDX2 to the supernait with RCA I used with my old Audio-video Amp, but I notice there is a Naim BNC in the box.
Should I change the RCA with the BNC ?
Why not use the ‘lavender’ DIN interconnect cable that came with the NDX2 ?
The BNC >RCA adapter is meant for the BNC equipped Digital input and output sockets if you don’t have a cable fitted with a BNC plug.
My question was badly formulated.
what is best : the ‘lavender din’ intercable or a RCA cable ?
Ah… understood
DIN is the preferred connection type between Naim kit. Give it a go and see what you think.
Remember to select the DIN output setting on the NDX2 and don’t have both the RCA cable and DIN cables connected between the NDX2 and SN3 at the same time.
Thanks for your answer.
I am now in DIN configuration !
@brous can you hear a difference now that you have switched to DIN, and if so, how would you describe it compares to the RCA you were using before?
