Good morning ,
This is my first post I am writing to you through the translator forgive me.
I have equipment that I bought in Poland as XS-2, this symbol is on the carton and the serial number matches it, while on the back panel there is the inscription XS. I am enclosing photos, I wrote to Niam, but I have not received any answer yet, so I am asking you for some answer if someone had such a case. Is this a normal situation? They say in the store that I have the XS-2, but I don’t want to believe something.
That serial number is a 2012 unit. The original Nait XS had a midcycle refresh where the front fascia was changed to match the style of the Classic range, whereas before it looked like the 5 series. Those were labeled XS-2, but they are not what Naim eventually called the second version of the XS as XS 2.
As such, you likely have an XS-2, might just not be what you thought.
