Morning all
My brother has just given me this,
Which unit is this from?
Is that box some kind conditioner?
Tried the search could not find this one,
I am guessing as I don’t have it any more, but I thought the supply for my Uniti Serve had such a lead.
I think so too.
And me, been trolling the web,
Found a few pics of the Uniti serve, with this lead,
Thanks for pointing me in the right direction,
Could I use this on my CB kit?
Is it worth it,?
Not sure, but I think there is some sort of ferrite in there … harmless; you can use it on all the CB kit
I also suspect there are just ferrites in that box. Uniti serve has a switch mode PSU, so i suspect the ferrites were added to try and mitigate any EMI originating from the PSU getting back into the mains.
This is indeed a Unitiserve lead with a ferrite ring in the plastic box, added due to the fact that it uses a switching power supply. There’s no reason you couldn’t use it on anything else that requires a standard IEC mains lead.
Thanks, I’ll give it a try,
Just got some bog standard leads at mo,
