Hi guys just a quick question… just wondering what my nx (reasonably priced) upgrade should be?
Power lines instead of the power line lites
Or
Full fraim instead of the fraim lite…
Or
Acoustic plinths under the speakers (already got Gaia’s so not sure this is really going to be an upgrade)
Sorry, I can’t help there. I’ve only ever used it with the 555, other than by itself briefly to see what the 555 does. The 555 does rather lend a magic to anything it’s connected to.
Yes I can imagine… I listen to it on its own for a few weeks then bought a TP ps…( which made it worse) then finally bought an xps 2 which made a great uplift (when warmed up)
either mains cables or fraim would be beneficial .
You’d be better ask a specialist who has experience with that sort of equipment trust him & deal with him
If buying used, first deal sourced would do
Dedicated mains, regardless
