What’s the difference between Tidal and Tidal Connect
Hi,
The title says it all. I have no idea what the difference between standard Tidal and Tidal Connect is.
Currently I subscribe to Qobuz and I am happy with it. My current subscription lasts until November but know Tidal will hopefully stream in 24bit hires.
Thanks.
Tidal Connect lets you connect to the streamer from the Tidal app. You then won’t need the Naim app, which you need now to enter your credentials and then select and play Tidal tracks from the Naim app.
It is convenience, most of all.
Understood. Thank you.
It’s a convenience, but also the Tidal app is often easier to find results of searches than from within the Naim app.
This is absolutely why Tidal Connect is great.
The Tidal app is slick with a good UI. It offers easy searches and linkages between artist/album, plus related artists, contributors etc.
Driving Tidal from the Tidal app is a far better experience than using the naim app for Tidal.
Just wondering if the sound quality is the same?
When I use Tidal with the Atom, the player doesn’t seem to display the file type and the quality versus if I use Tidal from within the Naim app, “FLAC etc etc” is displayed in the streamer.
Tidal Connect is just a way to control the streamer. The audio flows directly to your device in lossless FLAC format.
You can see the stream details in the naim app if you launch via Tidal Connect then open naim app
What a streamer displays when Tidal Connect is used is probably controlled under agreement with Tidal, but who knows!
100%, probably. Unless Tidal has done something in their connect software which differs from retrieving it from their API layer. But if I would have to guess, I’d guess that the Tidal connect software in the streamer utilises the same API to retrieve the data from their servers en doesn’t have some form of DSP build in.
