Looking at the Neat website it looks like the Ekstra’s have been discontinued anyway
Yes, my fabulous Neats have been discontinued too.
In terms of performance neat ekstra superior to neat mythic classic ?
I know treeble is with ribbon on the ekstra and the basses goes lower
I have the PMCs you are considering with a Supernait, I had an XS previously. In a similar size room I’m very happy with the sound. Small adjustment to position make a big difference have found, so if you do buy them, worth taking time to get it right
I had an xs2 that worked with a Neat Ministra, the room is smaller than yours, I turned off the subwoofer because it was too much in terms of bass, since the Ekstras is the big brother of the Ministra, and your room is 25-30 m2, provided it is sufficiently damped, but not over-damped, you should get exactly what you described.
