Hello, I am new to the forum. Thanks for the acceptance.
Recently, I got a Naim Nait XS3. I have an MC Denon 103R capsule and I want to buy a Naim Stageline Phono MC. I don’t know what is the correct version that fits my Denon: K, N, S or E? Please, Can someone help me?
Thank you!
Hi and welcome,
I think all the Denons are high output but I can’t be specific as to which model you require. @Richard.Dane is very knowledgeable if not call Naim they are very helpful.
Lindsay
The DL103s are all low output MCs. The 103R is rated at 0.25mV. Your best bet would be an S or K, probably safest with the S.
Perfect. Thank you,
I can connect this Stageline directly to the XS3 Amplifier, right? That is, without the need of an external power source or a FlatCap?
Yes there is an specific socket to power the Stageline.
Perfect! Plug and play between xs3 and stageline! Woderdull. Thanks!!
When I first had my Roksan I had a Stageline S powered by my 282. It was excellent.
Yes, you are right, 103R is 0.25mV and also need 100+ Ohm load on MC input of Stageline. So S or K depend of MC input Ohm.
All the best
Apparently, the pre phono integrated in the new Naim XS3 and Supernait 3, correspond to the stagelines. I asked Naim directly and they confirm it. although they indicate that the results should be different to be pre-integrated vs. external …
Yes but please be wary because the built in phonostages in the new integrateds (such as yours) are configured for MM cartridges, not MC.
