Which Cisco 2960? Does it matter
Hi,quick question I hope. I have searched but answer isn’t easy to find. :blush:
Does it matter which model of 2960 I buy? I’m looking to replace a cheap unmanaged 24 port switch in my network.
Anyone know if this model is good?
Cisco Catalyst 2960-S (WS-C2960S-24TS-S V02) 24 Port Switch.
Thanks in advance
IIRC, the 24 ports have a fan so not one for the listening room. A good bit of advice here -
Thanks for this @james_n !
Switch isn’t in my listening environment.
Does anyone know if I hang an 8 port off my existing chespo switch if it would have the same SQ benefits? Or am I better replacing the cheapo? Thanks
I’d go the other way… I hung a netgear that fed tv etc off the Cisco feeding the hifi
I like this one
Cisco WS-C2960CG-8TC-L
It provides the ability to go optical should you wish to do so in the future
Best
Gregg
Bear in mind that you may not notice any sound quality benefit from installing a Cisco 2960 in place of your current switch.
I am very happy with my two Cisco 2960 switches. They provided me with the extra ports I needed, but I didn’t notice an uplift in sound quality (nor did I really expect one) when I installed them in place of my TP-Link consumer quality switches.
Personally I preferred to use only the Cisco, connected to my router. It uplifted very clearly the sound vs my Netgear cheap switch.
I have booth 24 and 8 port 2960 and the 8 is a bit better and you also get rid of the fan noise from the 24.
Both are great switches.
A bit nerdy but I have also been experimenting with power supplies and finally put a toroidal transformer which made more difference then 8 to 24 port :grin:
I got a refurbed 8 port Catalyst Cisco 2960G GB switch and even in my modest system it did make a sound improvement over the TP link one I was using. Going to Catsnake 6E cable from this to my Innuos Zen Mini from the Cisco also gave an SQ improvement over the Cat 7 AQ pearl I was using before. Not night and day but a definite improvement.
