Which DIN to XLR cable
I have a Supernait 3 with Hicap DR and considering to buy ATC Scm40A speakers but I am wondering which brand I should buy. I currently have WH Phantom speaker cables and compared many cables before I settled on these. With din to xlr it is not that easy to compare. Does anyone has experience with this?
Naim makes a DIN to XLR cable (for connection to a NAP250) but I’m not sure the pinouts in the XLR plug would work for you (and you’d need two).
I know that Chord have traditionally sold a number of cables to accomodate these configurations, tried and tested.
I believe these are only 1 meter long which won’t cut it to the speakers. :grimacing:
These cables were not wired for balanced connections that your speakers use. They were for the unbalanced XLR input on all NAP250 models except for the current New Classic version.
Chord makes those, especially targeted at Naim users. Different lines at different price points, so there is even something to choose within a budget.
