Hi
How do I connect a ndx2 to my 32.5?
Hi
Did you get a 5 pin Snaic with the NDX2? If yes - connect to any of Tuner or Tape 1 and 2 on the 32.5.
No I didn’t get any connection with it
You need a standard 180 degree 5-pin DIN-DIN Interconnect cable.
Connect the NDX 2’s 5-pin DIN analogue output to the TUNER input on your 32.5, using the 5-5 pin DIN interconnect supplied with the NDX 2. Avoid the phono input, which is intended for a turntable.
Shame. 5 pin SNAICs aren’t exactly cheap. I guess that’s why sellers hang onto the ones which are in the original box.
The DIN interconnect should have been supplied with the NDX2. If you didn’t get any of the stuff that should have been included, talk to the seller.
Note that it’s not a Snaic that’s required. A Snaic is not supplied with an NDX2.
What’s needed here is a 5 pin standard interconnect, which can be bought from Naim dealers for £129.
It’s all a matter of degrees then!
Add: I’ve learnt something there. As someone who just plugs in whatever comes in the box into the sockets indicated in the instructions I’ve never thought about the differences.
The lavender DIN5 IC is included with NDX2. Should be no need to source one separately unless you want an upgraded cable (HiLine, SL, etc).
£99 pre-loved.
I’m fully aware of that. If you look at post 3 you’ll see that the OP did not get an interconnect with their NDX2, hence my post.
If it’s buy new it’s a mistake, but if it’s a second hand, you buy what the seller sell ![]()
You could use a pair of RCA leads. You’ll need to select the RCA output in the settings menu via the App.
Note: using a genuine Naim grey/lavender interconnect, lead that should’ve came with with your NDX 2 in the box, may give a better performance and that’s the route i’d choose over the RCA one.
Thanks to everyone
I think I’ll go to my dealership and explain my situation and use the opportunity to compare the missing lead so to speak and the hi-line.
The super lumi is above my pay grade
You live and learn
M
Depends if the BNCs have been ‘upgraded’.
If not, the unit should have the proprietary RCA/BNC adaptors.
