Well done for taking the leap of faith!
You maybe benefitting from synergy due to your Kudos Super 20s, nice speakers!
KS-1 is a very odd cable, tends to challenge everything we believe a speaker cable should and shouldnât be; chunky and expensive good, cheap thin bell wire bad.
But KS-1 certainly isnât cheap bell wire, and we can confirm it ainât chunky either!
There are cables out there that better it, but theyâre in a completely different league of expenditure.
I hope you are well, though it seems you have been cloned!
The Bristol Hi-Fi Show in February when we met, seems like a lifetime ago now - at least I was able to visit the factory just before lockdown. Iâll probably need to provide a full Body Scan Certificate before they will let me in again!
I have just treated myself to some Phantoms from Witch Hat and I have to say Iâm mightily impressed from the off. They replaced black Naca 5. The difference is noticeable and I am enjoying them a great deal.
I am finding the same. So much so that I have taken a day off work to enjoy them after the amps have settled down. Significantly better than NACA5 and great value for money. More detail, refinement and better dynamics.
An up-vote for Kudos KS-1. Nice balance of detail, bass, clarity, range, and a better match for my system than the QED Supremus that are now relegated.
I also have the Supremus although on a non Naim system⌠I think their strongest point is having wide soundstage and refined treble extension⌠How do you think the Kudos compare ? any part that is lacking compared to Supremus ?
@Tolomeo I found the Supremus was an improvement on my trail of cable trials at the time, had more bass, clarity etc, and are a good cable. Reading this forum got me curious about its capacitance/inductance match for Naim amps, hence the KS-1 test. I donât know itsâ specs but it is a step up in quality all round in my system over the Supremus. Iâm sure Supremus with other amps is up there.
All of you have recommended several cables instead of the NAC A5 which is too rigid a cable and thank you very much. But the problem is that my NAP 250 is N. 1400 as standard and could fail with different cables.
Take the recommendations youâd consider, and look at their specs. You need low capacitance, NAC A5 is 16pF/m, so at 3.5 meter that will be 56pF. A visual clue is generally that the two conductors are spaced out.
Apart from low capacitance, itâs more important to get the right inductance. Thats the reason for the 3.5m cable length, the Naim amp output stage needs a minimum load of 3.5uH, (better to have more) & NACA5 has 1uH per meter, so 3.5uH means 3.5 metres.
But finding cable spec is not always easy, the cables with parallel conductor spacing give a clue to being most suitable, but twisted pair cable types wonât damage the amp. The cable types to avoid & have the potential to cause the amp to shut down are the woven, plaited & litz types, these all have exceptionally high capacitance.
Regarding manufacturers not providing specs, simply avoid those would be my advice. Would you buy an amp without a rated power? Itâs the most basic of info about any cable, I canât even think of why they would want to hide those numbers.
