Allow me to rephrase, I suggest you purchase an LP12, Rega, or other brand at a component level that will compliment your current system. There are plenty of turntable brands and owners out there on the forum that are happy, and prefer their chosen brand and sound at many price point levels.
Just go for the Linn Klimax LP12 with all the glorious latest updates (including a pink-colored plinth).
Alternatively, a Rega Planar 3 LP Turntable + Rega Elys2 phono cartridge.
@Whiskymat I would not, no way buy your friends old LP12. If it goes belly up or you have issues do you really want to be hounding your friend? Iād suggest getting a table that wonāt need much if any fiddling. A table that wonāt need upgrading. Iām going to suggest an SME, Basis, Clearaudio, VPI, Kuzma.
I am very happy with my LP12 which I bought 1995 in a quite a basic state. Setting it up is a bit tricky, thatās true, but once this is done correctly itās simply a great sounding machine! Slowly, as my SchwyzerfrƤnkli-Account (CHF for the rest of us) allowed it got some upgrades.
And yes, we have very good people in Switzerland for servicing, setting up and troubleshooting our LP12s (e.g. Lüthi in Thun if this mention is allowed by forum rules, no interests with him except my LP12ā¦).
Depends whether you want simple or the ability to tweak and obsess.
If itās the first, buy the Rega you can afford. If itās the second consider an LP12. But be prepared for a life of tweaking and rarely being satisfied.
If you want a cracking alternative to a Rega, then consider a Michell Gyro SE, Rega rb330 arm and an Benz micro SL cartridge. It plays well, sounds great, minimal tweaking and always gets comments from visitors. Always.
I HIGHLY recommend that if he buys a Rega he stay with a Rega cartridge that can be fitted without modification of the tonearm. (I donāt think thatās the case with a Lyra cartridge.) The beauty of Rega being āplug and playā is that it comes fitted from the factory or distributor; no cartridge alignment or anything is needed.
Yes, however i preferred clearly the Delos vs Apheta 2 on Rp10 when I listened at my dealer place.
I bought an ex demo Rp10 fitted with the Apheta 2. Listened.
Then my dealer installed my Lyra Delos with a spacer. Preferred it.
The phono was a Rega aria.
Love my Gryo SE from a certain dealer in Maidstone.
I trialled it against a Rega RP8 albeit with a different cartridge. No contest.
Beautifully machined and put together product. Minimal maintenance. Set it up, and forget.
And currently playing a now clean copy of Zenyatta Mondatta.
The Naim dealer in Maidstone is the closest to where I live. However when my old Musical Fidelity A1 amp developed a fault I called them as they are a MF dealer as well. They were very unhelpful so I called the Naim dealer a little down the M20 in Ashford. Even though they arenāt MF dealers they couldnāt have been more helpful so when it came upgrade time they got my business instead of the dealer in Maidstone. Iāve developed a good relationship with them so they will be the first port of call for any future purchases.
And that is a salutary tale , I bought at least three Naim systems plus a Quadraspire system and an LP12 from one dealer , a couple of duff auditions where I didnāt purchase now leads to him not returning emails.
I am retired but in the last 18 months or so have rebuilt about 75% of my system so only the CD player he sold me in 2003 and the tuner he sold me in 1989 remain, but we are drifting off thread .
Same here. Iāve owned mine since the late 70s and never felt the need to go beyond Valhalla and Cirkus. In fact I didnāt even ask for the Valhalla - my dealer fitted a used one FOC when the deck went in for a service
I donāt know what it is like in the UK but in the states I bought a Rega table online and it came fitted with a choice of nice cartridgesā¦I got the Denon 103
I had a Rega Planar 3 for almost 40 years. Traded up to a Verdier at the turn of the century.
If you are serious about vinyl you can look at the P8 or P10. If you live in the middle of nowhere, you can ship it to a dealer and they can set it up and ship it back via UPS. Truly plug and play. With a Linn (or Verdier), the dealer has to visit you, which is not a trivial expense.
I have never needed a dealer visit for my LP12. I just carefully pack it then take it there and back myself. I do the same with Naim amps too as I prefer to avoid shipping companies.
If the OP goes for the second hand LP12, it is worth checking if it comes with the original box.
