I intend to use the inbuilt riaa in the NAC82
Depends on where you live, but contact Peter Swain at Cymbiosis in Leicester.
For that money, they could make you a very nice Linn LP12 with some pre-loved parts, which would compliment your existing Naim system.
I live in Sweden so Cymbiosis is a bit far away.
SL1000? That’ll blow the budget, or do you mean an SL1200 variant.
No SL-1000. It was a joke
Have a word with them anyway. They can give some guidance, plus he does travel the world doing this.
Now have an ex-demo Goldnote Mediterraneo with Donatello red cart to evaluate. It sure sounds nice is the initial impression.
Check out the Kubrick DCX with Rega arm on The Swedish sites. A friend of mine sells it. Awesome deck. The P8 is like a toy in comparison.
Looks like a serious record player. Thank you.
