Who is cleaning his lps without a machine and why
I have been using the Knosti manual cleaner recently following Paul Rigby’s ( who preferred the Knosti to the spin clean due to the abrasive cleaning goats hair brushes )
recommendation on cleaning fluid and surfactant on audiophileman.com where he has identified that the supplied cleaning liquid supplied with the Knosti left a sticky residue on the stylus. This was my experience and was finding my HanaLM clogging up regularly. Since changing to the distilled water bath with 7% isopropyl alcohol and using a surfactant of distilled water with few per cent of glycerol and Triton x100 the stylus is far cleaner and I have seen records previously unplayable return to service and improved detail to cleaned records. How this compares to a vacuum model I don’t know , but I have certainly heard good improvements and it has given me something to do during lockdown this year!
Received the Groovewasher. Difficult to evaluate vs other methods right now, but this fluid is very highly rated among a lot of forums.
It’s easier to manipulate vs the Art du Son. I rinse with a sterile pad 4 times, in the direction of the grooves. My two NM lps from the 70’s , just received, are now quiet dead quiet.
I will however use the Art du Son for lps that need a serious cleaning, and rinse after many times with sterile pads and distilled water.
Not sure I will go for a machine.
