Whilst scrolling through the ‘What are you listening to’ thread I have been interested in the varied ‘now playing’ screenshots that members post. Particularly using what I assume is the Naim app and through similar equipment to my own. For example here is one of my recent posts:
I suspect you are just looking at three different screens. The first is upnp from a local server, the second is a stream from a server that may not be local and the third is from a playlist? Or something like that.
I believe there is also variation in appearance depending on whether you are using the first or second generation streaming platform. Both platforms use the same app, but I noticed differences when I switched to the second generation.
You can call the UPnP input whatever you like. I call mine ‘Stream’, inspired by the illuminated input display on the Statement. Just to make the point…
