Here are some recommendations by Dr Chasin, from the Piano Passion site, to set up the hearing aids for music. Set up by an audiologist.
« Start with Post-16-Bit Architecture
What to tell your audiologist: First, be sure to select hearing aids that have 20-bit or 24-bit architecture to allow for a higher input level. Then start with the optimal “speech-in-quiet” program for the patient and make adjustments from there to create a custom music program.
Here’s why: In some hearing aids, all sounds can’t necessarily get into the hearing aid for processing because the old industry standard 16-bit systems have a maximum input level of 96 decibels. Music can be louder than speech with more dynamic peaks, so louder elements would be clipped or distorted. Many newer hearing aids do not have this problem, but it’s important to make sure you’re starting with an appropriate model.
Dial Down Compression
What to tell your audiologist: A low compression ratio of 1.7 to 1 (or a maximum of 2 to 1) is best for music.
Here’s why: The compression ratio represents the change in loudness that comes into the hearing aid versus the change in loudness that goes out of the hearing aid and into your ear. Too much compression essentially over-processes the sound, causing music to sound dull and lacking in dynamics.
Turn Off Noise Reduction
What to tell your audiologist: Disable the noise reduction system for the music program.
Here’s why: The noise reduction system is designed to reduce the sound of the microphone inside your own hearing aid, but this feature sometimes has detrimental effects when used for music.
Turn Off Feedback Management Circuit
What to tell your audiologist: Disable the feedback management circuit when setting up the music program.
Here’s why: The feedback management circuit is designed to prevent you from hearing the squeal of your own hearing aid. But sometimes it can’t distinguish between the whistling of your hearing aid and a harmonic or a musical instrument.
Turn Off Frequency Shifting
What to tell your audiologist: Disable any frequency shifting or frequency transposition for the music program.
Here’s why: Frequency transposition customizes sounds to your particular audiogram by moving some tones to a lower frequency. It can help a lot when listening to speech—but for music, it means your hearing aids can actually change the notes and octaves on you if this feature is turned on! Should your audiologist have additional questions,«
What do you think of these recommendations, @davidhendon ?
