Ok. I have the latest Isotek Sigma v5. Much more costly than yours. It really does well in my system. However every system snd electrical environment is different. Good luck.
tried source first vs amp first and I personally found the former way sounds better. When amp first I found itās a bit too HiFi, somewhat exaggerated for my liking.
@Jaybar I saw you mentioned Isotek a few times, but I bet Naim amps donāt design with power conditioning in mind, and not even recommend using? With a proper setup you got the best sound from Naim.
@juliushui lots of factors entered into this. I donāt have enough wall outlets and even if I did, our disability prevents us from easily getting to them. Lastly we have a lot of line noise in our building in NYC and the Isotek lowers that significantly. I trust my dealer and his tech. Both are big proponents of Isotek.
As Dan says, just experiment. I have my power amp into the wall socket, which for me works best. Then the matrix plugged into the other socket connected by a PL. My socket order is: Preamp, Core, Armageddon, gap, PS1, PS2. This sounds pretty good to me and, for some reason, better than everything plugged into wall sockets.
The Polaris sucked the life out of the NAIM sound I love. Dull. Unexciting. Too much āfilterā perhaps.
Right now, I have the Supernait 2 via the Vertere Redline into a wall socket.
On the other wall socket is now the Matrix 2 via another Vertere Redline.
On the Matrix 2, I now have the following order: (from the wall outlet to the right)
I repaired one of these a few years ago, not very impressed with quality, but thatās another thread.
Yes it is wired in what you call āstarā.
In UK/EU itās called āradialā, the link to the 2nd socket is a ābranchā
I agree, the plug-in order should make little or no difference.
