Hello Naim People ![]()
I have one question please,
looking at the power plug from the rear panel, which pin is the live and which one is neutral please?
I have the NSC222/NPX300/NAP250
thank you, Jean-Paul
Just in case you are confused between plugs and sockets.
The female socket is the part on the power lead.
The male plug is the part on the Naim box
thank you so much for helping me, I do appreciate.
so looking at the back panel of the naïm box , the Live pin is on the left, right?
is it the same for the classic and the new classic?
Yes Live is Left on the ‘Male’
It’s the same for every electrical device on the planet, it’s an international (IEC) standard.
I’d be inclined to answer with a question. Why do you need to know? All IEC mains leads are wired for conformity and if you make your own, the inside of the male plug is clearly labelled in some way.
In my field of work, I often get seemingly innocent technical queries from customers which are easy to answer but often send alarm bells ringing as I think, hmmm what exactly are you trying to do?
