Been scouring the net for definitive wire connections for RCA to 4 Pin Din.
See photos. Both left and right RCA plugs carry audio via the red wire for pins ch1 and ch2.
The blue and black wires are connected at the RCA end to the outer ring which is negative (-ve). So to my mind the -ve then receives 4 wires, 2 black and 2 blue to complete the din plug.
Yes - you’re correct. The RCA plug pins connect to Ch1 and Ch2 respectively (ch1 = left, 2 right) at the DIN end. The RCA outers connect to -ve.
There is no 24v rail on the NAP100 amplifier’s DIN4 socket, unlike some of the other Naim power amps, so no worries here about feeding 24v where you don’t want it.
