I have an old Roksan Tabriz/Goldring 1042 from aeons ago, which I had rewired with Audio Note silver wire.
I’m wondering if it’s worth doing anything with, now I’m looking at a new turntable next year. It should partner well with a Roksan TT but not sure about anything else.
Not sure what it compares to nowadays and if I should just make a clock or other project with it!
It was a great tonearm and assuming not maltreated should be fine. What TT are you thinking of buying? It would work well on a Roksan Radius. As for others, the Nima works well on a LP12, I’ve seen a Tabriz on a Michell Gyro which worked well.
Definitely worth keeping. I had one on my Little Pink Thing where the Tabriz tended to be offered as an alternative to a Rega arm. No reason why your Tabriz shouldn’t perform well on any deck that will take a Rega imo.
I found the ‘-zi’ counterweight to be a good improvement too.
Now that’s a name I’ve not heard for a while! Another sad loss to the industry but reading up, the successor seems to be the Funk Firm, who I’ve never heard of.
Thanks for the info though. It’s looking like I may end up buying a TT without arm and doing it separately.
Nothing wrong with a Tabriz. If you can get along with their look, a Vertere turntable should be fine. Vertere is the current company of Roksans founder.
