Okay, I’ll admit it, I was bored. I know, I thought, I’ll fettle and fiddle. In the past this has often involved looking for a problem that doesn’t need a solution, but, as I said, I was bored.
I turned my attention to cable dressing. Actually, I was quite pleased with the cable dressing I’ve done recently and thought there wasn’t much mileage in this.
I then spotted two significant coils of XLR cables right next to my Fraim. These are the cables that connect my NAC332 preamp to my active ATC 40A active speakers.
You often end up with a surplus of this cable as it connects the hi-fi to the speakers. One speaker tends to be significantly closer to the hi-fi, creating slack. Additionally, I had to order 8m lengths which was the option closest to my requirement of 6.5m. This generated quite a bit of surplus XLR cabling.
I consulted my buddy AI (A.I., not Al) and he said, contrary to popular belief, longer lengths of XLR cabling does benefit from dressing. No sharp coils, keeping away from power cables and power supplies, all helps.
It took about 15 minutes to remove the excess coils of XLR cables from next to the Fraim and transfer the excess to behind the speakers, arranged in zig zags.
I also made sure the XLR cables did not touch any power leads and was away from power supplies at the Fraim end.
It is quite difficult to do A/B testing with cable dressing, so I simply listened again to some tracks/albums I’d recently heard prior to cable dressing. There is no B/A testing as it is impossible to re-create the XLR cable mess, and no sane person would do that.
This is an album I listened to yesterday, Beth Hart, ‘War in My Mind’. It is an incredibly tricky album for any system, with a number of the tracks reaching loud crescendos with a wall of sound. Yesterday‘s listen was an improvement in what I was used to with this album (the effect of the addition of the second NPX 300 power supply in my system). But the wall of sound aspect of this album remains a challenge.
Listening to this album today, post XLR cable dressing, seemed to make a little more sense of those crescendos, and Beth’s voice was a tad cleaner, with a trace of glare removed.
It is possible I was still hearing the effect of the NPX 300 being added and I do have a new Puritan Ultimate power cable burning in. But I have to say, although small, I’m pretty sure I detected an improvement from the XLR cable dressing.
I then moved on to a test album of mine, Antonio Antonio Forcione and Sabina Sciubba, ‘Meet Me in London’. Again Sabina’s voice seemed a tad clearer and a tad less congested. Bass seemed a tad firmer and slightly more resolved. The whole presentation was slightly more relaxed, but yet more engaging.
You can only ever expect small changes in SQ from cable dressing, but those small changes (improvements) can add up to a noticeable enhancement in engagement with the music.
I realise this story mainly relates to those with active speakers, as we are talking about longer lengths XLR cables. It does however underline the value of good cable dressing generally in my view.
So balanced XLR cables are inherently clean and relatively noise free connections, so you don’t need to pay attention to dressing them…right? The only way to truly answer that question is to try yourself. It only took me 15 mins and relieved my boredom.
For those that can be bothered to spend 15 minutes doing what I have done, I would be interested to hear your thoughts.
