252 Selecting Wrong Channel
Hi there, I’m sure I’m going to kick myself when I work out what the root cause is, but for the life of me I cannot work it out…
Basically, I was previously using Aux 2 to play music through my 252 using RCA cables. I now use a DIN cable via the CD input. Despite having re-programmed Aux 2 back to DIN from RCA, whenever I play music (either via Roon or the Naim app), the 252 switches to Aux 2 rather than CD. Any ideas on what I’m doing wrong as it’s very frustrating?
Options to resolve are linked in this thread:
Perfect, thank you very much. The fix was under system automation settings - the preamp was routed to channel 6. Simple change to #1 and it now works.
Thanks again, I would never have thought to look there :+1:
