Hi,
Sorry if this has been covered but I can’t seem to find an answer.
I am running a 282 with single hicap dr and possibly changing hicap for supercap dr.
Would I need a second snaic cable,if so what do I need as I’ve been led to believe the supercap is only supplied with the power cord.
Yes, you will need a second SNAIC5 cable, so you’ll end up with two SNAIC5 cables between 282 and SC.
Thanks James.
When searching will I just put snaic 5 because I notice some have a degree associated with them.
Sorry for the novice question.
Thanks James,appreciate it.
They’ve become pretty expensive at £199, but they are very common used. There are a few on eBay for about £75. Just make sure you get proper Naim leads and not £25 imitations.
