5 pin Din plug repair
Looks OK to me.
Hi, Richard!
Thanks for the quick response. Yes, I have read this topic before.
This is not the first time I’ve come across SNAICs, and all of them had the inscription coming from a marker, but this one goes towards it - that’s what confused me
And yet, how to connect this cable using a marker or an inscription?
Direction is determined by listening at the factory so the printing is not a reliable guide. However, to make things a little bit more tricky, I’ve seen SNAICs where the band has loosened to the point where it can be moved up and down the cable. Is the band on your loose at all?
The green ribbon is glued and the transparent tube fits quite tightly although it rotates a little but it is impossible to move it to the other end.
OK good.
Thanks again.
So what way round then.?
