And it’s getting worse and worse.
My setup consists of NDX 1 / 282/250DR/HICAP, all bought new between 5 and 7 years ago. Worked fine, happy with the sound, especially in combination with the detailled, precise sound of the Wilson Benesch Vectors.
I can’t exactly remember when the disconnect started. Suddenly the music stopped, had to reconnect, sometimes restart, annoying but not a huge issue. Or at least, not enough to really want to investigate or do someting about it. And to be fair, last couple of years I only occasionally seriously listen to music, most of the time it’s just background internet radio. But now the disconnects occur so often that it’s even frustrating with background music only.
Two years ago the display of the NDX broke down. Was replaced at the official importer (dealer is no longer in business).
Now, what do I mean with “disconnect?” The NDX seems to loose connection to the network. There’s no way to reach the NDX, the app is non responsive (either shows “there’s another device connected” or “sorry, we’re having trouble finding devices on your network”), I can’t ping it etc.
And to get the NDX back to life either a hard restart of the NDX or a input selection → P1 tuning or P5 error code → restoring connection → press play (internet radio) will restore the music.
Again, the number of disconnects is getting higher over time.
Browsing through topics I see that I’m not the only one, I see similar issues and many immediately pointing towards the network. It has to be the network!
Which I’m familiar with (working for the largest manufacturer of networking kit in the world). And we also know that it’s in almost all cases not the networks fault.
Anyway, for reference, the internet (cable) modem is the COMPAL CBN CH7465LG-LC, which handles the DHCP duties, the built in switch is connected to a Meraki MS220-8P switch, and the NDX is connected with a Cat6 cable to this Meraki switch. Furthermore there are 3 Meraki MR33/MR30H AP’s , but as the NDX is Ethernet connected that 's less relevant. Connecting the NDX directly to the built in swith of the Compal has the same result.
I deliberately keep it as simple as possible, both networking as my wording (and off course I ran all tool I have at hand…).
What to do?
