I think you are right. I would be amazed (but delighted) if someone offered me that price.
Eeh, lad, considering that my first house were a cardboard box in the middle of tā motorway, ā¦ you were lucky, etc. etc.
Mike, get your wife to give you a hand with figuring out the percentages ATB Peter
Well, I say house, it were more of a hole in tāground
Well, I say hole, it were more of a puddleā¦
My second house was 1990
But to try to get into the actual topic, I am (in very rough terms)
Sources 40%
Pre and power 30%
Speakers 20%
Balance cables and fraim 10%
Here are my rough percentages and as lob sided as they come:
Source: 21%
Preamp: 45%
Amp: 14%
Speakers: 10%
Mains, cables, Fraim and room treatment:10%
ATB Peter
Surprised me as well, but In my defence, I got the Sibbles at a very, very good price, and being active, they need 4 runs of NACA5. Supplement that with a few forays into third party interconnects - nowt extravagant, mostly W*******, and it just about tops the cost of the speakers.
And no overpriced mains cables either!
Hereās mine
Source - 18%
Amp - 27%
Power supplies - 10%
Speakers - 18%
Cables - 18%
Rack - 9%
Source 23%
Amplification 48%
Speakers 22%
Cables, stand, power 7%
My allocation is almost identical to @GraemeHās, as the only significant difference between our systems is our sources (full monty digital vs analogue). Percentages calculated from current UK new costs. Long live the monkfish
Source: 40.3%
Pre: 44.5%
Power: 8.5%
Speakers: 3.2%
Cable: 1.5%
Support: 2.1%
Hurrah!
But not as much of a place as speakers, which is what surprised me, given the influence speakers have on the sound.
If you find a pair of loudspeakers that works with your room, both acoustically and aesthetically, then thatās a fix for me. One could spend a lot of time and money searching for something ābetterā which successfully ticks both these boxes.
Iāve had so many āspeakers in the past that niggled in a āit must be the roomā kind of way; S600 no bass, Proac 1SC mid-bass hump etc etc. The Tab 10 Sig. just nail it, regardless of price.
Nailed it there Graeme. If the speakers just donāt work in your room then nothing you do further up the chain is going to fix that.
Iām surprised by your āno bassā assessment of the S600. Lots from mine - much more than the SBLs, and very clean. Not as much as from DBLs, but then the S800 pretty much did that.
āā¦It must be the roomā¦ā
Interesting question. My source has multiple boxes and cables connecting them and the preamp is built into the source. Valued in that way;
Source 55%
Amp 23%
Speakers 22%
All-in-one 48%
Speakers 48% (incl subwoofer)
Cables 1%
Network/storage 1%
We have spent a lot of time trying out speakers in our lounge but happily not spent any unnecessary money thanks to out excellent dealer. Speakers are the hardest thing to get right. Itās as much about how the room plays them as how they play in the room. Good speakers must resolve, time well, and all that, but most of their characteristics are about the room they are playing in.
This is why we happily ran Spendor S5e on the end of 552/500 until we found another speaker that actually sounded better to us, as opposed to just different. And probably also why the speaker we ended up with was a brand we have never rated - until we heard it on the end of our system, in the intended listening room. That particular quest took over a year. The search which had previously resulted in the Spendor took several months.
Well, I donāt exactly skimp on the speakers (they cost Ā£6,950). In reality, the speakers are the most important component to me as all other components are built around it. Itās just that I overspent on the āaccessoriesā .
